Enables you to forward packets for the LLMNR protocol to the VLAN for learning.
| flood | Specifies to forward LLMNR to VLAN. (Default). |
| learn | Specifies to send LLMNR to the CPU for learning. |
flood
Use this command to enable LLMNR to a flood or learn state.
When flood to VLAN is enabled, an actual ACL filter is installed, and one ACL entry is consumed.
When in learn mode, no ACL filters are installed, and no ACL resources are consumed.
The following command enables LLMNR to flood to VLAN:
configure forwarding ipmc llmnr flood
This command was first available in ExtremeXOS 32.2.
